1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Vdct and autosave's info field
To: [email protected]
Cc: "Alarcon, Arturo" <[email protected]>
Date: Tue, 13 Jan 2009 10:19:48 -0600
On Tuesday 13 January 2009 09:01:03 Tim Mooney wrote:
> Autosave (v 4.3 and later) does already permit info nodes to specify the
> fields that are to be autosaved.  However, I have not found a way to
> make vdct leave these fields in a database.
This doesn't solve the issue with vdct remembering info data (the ability to
do so will have to be coded into vdct; if someone needs this and is willing
to pay for it, I'm sure CosyLab will be happy to oblige), but you can at
least put the info data into a separate file.db that just contains entries
like these:
record(type,name) {
  info(key,value)
It wouldn't be hard to write a tool to pull just these items out of an
existing .db file into a separate file; ask me if it would help and I'll see
what I can do.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Vdct and autosave's info field Thompson, David H.
RE: Vdct and autosave's info field Alarcon, Arturo
Re: Vdct and autosave's info field Tim Mooney
Prev: Re: Newport ESP300 on Linux Ron Sluiter
Next: Re: webca can't connect to pvs? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Vdct and autosave's info field Tim Mooney
Next: RE: Vdct and autosave's info field Thompson, David H.
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
