1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: webca can't connect to pvs?
To: [email protected]
Date: Tue, 13 Jan 2009 08:42:11 -0500
That test.html file doesn't work for me, either. CAML 2.0 will be released very soon and offers much more powerful features. I recommend waiting for it. However, if you want to test WebCA with real PVs, I've written a simple probe page in which you can specify a PV and it will display some useful information about it in addition to live monitoring. It demonstrates the basics of WebCA. Let me know whether that works for you.
CAML 2.0 will allow you to simply specify rich controls and lay them out within HTML. You don't have to write any JavaScript (unless you really want to).
best regards,
tom
Attachment: probe.js
Description: JavaScript source
Title: CA Probe
CA Probe
PV: Unspecified
Value Count Status Severity Timestamp
Limits Lower Upper
Alarm
Warning
Operation
Control
On Jan 13, 2009, at 4:34 AM, Silver wrote:
hi,
I want to use webca. After compiling the code and copy .so file to mozilla's plugin directory. I use firefox to open the test.html coming with webca package. seems the plugin works, while I can't get the pv's value. Ps, I can use caget to acqure the ai001's value first, then start the firefox from the shell to visit that test.html file.
 Any help is appreciated. thanks a lot.
following is the webpage's context:
EPICS Channel Access Plug-in Test
This page contains a test case which test the implementation of EPICS Channel Access Plug-in Test
Test 	Result
Get EPICSPlugin scriptable instance 	PASSED
EPICSPlugin.version 	PASSED
EPICSPlugin.epicsVersion 	PASSED
Connection monitoring 	(unknown)
Connection monitoring (second) 	(unknown)
Connection monitoring (on connected) 	(unknown)
Connection monitoring (non-existant record) 	PASSED
Connection monitoring (second, non-existant record) 	PASSED
Get request (no blocking test) 	PASSED
- value 	(unknown)
- status 	(unknown)
- severity 	(unknown)
- timestamp 	(unknown)
Get string (enum) scalar 	(unknown)
Get double array 	(unknown)
Get long array 	(unknown)
Get string array 	(unknown)
Put request (no blocking test) 	PASSED
Put double scalar 	(unknown)
Put long scalar 	(unknown)
Put string (enum) scalar 	(unknown)
Put double array 	(unknown)
Put long array 	(unknown)
Put string array 	(unknown)
Put without callback 	PASSED
Put with wrong data 	(unknown)
Monitor request (no blocking test) 	PASSED
- value 	(unknown)
- status 	(unknown)
Monitor array 	(unknown)
Monitor destruction 	(unknown)
Best regards
Geyang  2009-01-13
Re: webca can't connect to pvs? Andrew Johnson
webca can't connect to pvs? Silver
Prev: RE: PMAC IP and motor records Rees, NP (Nick)
Next: RE: webca can't connect to pvs? Purcell, J. David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: webca can't connect to pvs? Silver
Next: Re: webca can't connect to pvs? Andrew Johnson
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
