1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: area Detector on cygwin, win32-x86
To: Timothy Madden <[email protected]>
Cc: [email protected]
Date: Mon, 12 Jan 2009 15:55:30 -0600
Hi Tim,
On Monday 12 January 2009 15:24:15 Timothy Madden wrote:
> The module, seq, will not build with EPICS-3.14.10. The same is true
> with sscan. There is some change in the source code that is
> incompatible. I think the file sscanRecord.c has a problem.  I don't
> know which file has bad in sscan. They do build with 3.14.8.2.
Are you building the right versions of those modules?  You do have to use the
latest version of the sequencer (2.0.12), as mentioned on the R3.14.10
webpage.  I'm pretty sure that Mark Rivers and various members of the BCDA
group have by now built most of synApps against R3.14.10, so there must by
now be newer versions of the relevent applications around somewhere.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
area Detector on cygwin, win32-x86 Timothy Madden
Prev: Re: area Detector on cygwin, win32-x86 J. Lewis Muir
Next: Vdct and autosave's info field Alarcon, Arturo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: area Detector on cygwin, win32-x86 Tim Mooney
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
