1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: area Detector on cygwin, win32-x86
To: [email protected]
Date: Mon, 12 Jan 2009 15:53:11 -0600
On 1/12/09 3:24 PM, Timothy Madden wrote:
> Folks
> The module, seq, will not build with EPICS-3.14.10. The same is true
> with sscan. There is some change in the source code that is
> incompatible. I think the file sscanRecord.c has a problem.  I don't
> know which file has bad in sscan. They do build with 3.14.8.2.
> Tim
Hi, Tim.
What is your environment?  What is the error you're getting?
Are you using seq 2.0.12?  This version or later is required for EPICS
base 3.14.10 according to (see near the bottom of the page)
  http://www.aps.anl.gov/epics/base/R3-14/10.php
As for the sscan module, have you seen this Tech-Talk thread
  http://www.aps.anl.gov/epics/tech-talk/2008/msg01293.php
If you're trying to build synApps 5.3, you may find other modules that
don't build also.  I ended up having to build from a synApps CVS
snapshot, but I can't deploy production systems against this.
It would be great if a new release of synApps could be made that would
work w/ EPICS base 3.14.10.  Tim Mooney, is this in the works, do you
have an idea of when this might happen?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
Re: area Detector on cygwin, win32-x86 Tim Mooney
area Detector on cygwin, win32-x86 Timothy Madden
Prev: area Detector on cygwin, win32-x86 Timothy Madden
Next: Re: area Detector on cygwin, win32-x86 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: area Detector on cygwin, win32-x86 Tim Mooney
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
