Title: Message
Hello Wangqisheng,
Looking at your Makefile, you need to add the
line:
mx_LIBS += oms
This
is the OMS specific library from the motor support package and provides the
MAXvSetup() function. Hopefully this will cure your
unresolved reference.
Ian
Gillingham
Diamond Light Source
Hello,everyone.
I have two application of oms motor and
hytec adc, but i only have a VME crate. So i need to merget the two
application to one ioc. The oms motor application from synApps and hytec
8401 work well respectively. So i use the makeBaseApp.pl to produce a new
application and revise the makefile, and copy the source file to
the corresponding directory. The compile is ok, i can get the munch and
st.cmd files.
When download st.cmd to the vme, there are will problems.
It is said the MAXvSetup is an undefined symbol. It is very strange. I insert
the hytec8001 and 8401 in the first and the VME in the third.
Please
give me some advice and
idea.
Thanks.
----------------------Makefile----------------------------------------- TOP=../..
include
$(TOP)/configure/CONFIG #---------------------------------------- #
ADD MACRO DEFINITIONS AFTER THIS
LINE #=============================
build an ioc application
PROD_IOC_vxWorks = mx
DBD +=
mx.dbd # mx.dbd will be made up from these files: mx_DBD +=
base.dbd
#include definitions for any other support applications
needed #mx_DBD += xxx.dbd mx_DBD += transformRecord.dbd mx_DBD +=
oms.dbd mx_DBD += motorSupport.dbd mx_DBD += motorRecord.dbd mx_DBD
+= devOms.dbd mx_DBD += devSoftMotor.dbd mx_DBD += PSU0.dbd mx_DBD +=
sscan.dbd
# <name>_registerRecordDeviceDriver.cpp will be created
from <name>.dbd mx_SRCS_vxWorks +=
mx_registerRecordDeviceDriver.cpp mx_SRCS_DEFAULT +=
mxMain.cpp mx_SRCS_vxWorks += -nil-
mx_SRCS_vxWorks += devOms.cc
drvOms.cc mx_SRCS_vxWorks += devOms58.cc drvOms58.cc mx_SRCS_vxWorks +=
devMAXv.cc drvMAXv.cc mx_SRCS_vxWorks += devOmsCom.cc mx_SRCS_vxWorks +=
devSoft.cc devSoftAux.cc mx_SRCS_vxWorks += motorRecord.cc motordevCom.cc
motordrvCom.cc
#The following adds support from
base/src/vxWorks mx_OBJS_vxWorks +=
$(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support
application used by this application #mx_LIBS +=
xxx
#NOTES: # 1)It is not possible to
build sncExample both as a component of
mx # and standalone. You must
choose only one. # 2)To build sncExample
SNCSEQ must be defined in <top>/configure/RELEASE
#The following
builds sncExample as a component of mx #mx_SRCS +=
sncExample.stt #mx_LIBS += seq pv
mx_LIBS += motor mx_LIBS +=
SoftMotor mx_LIBS += Ipac mx_LIBS += Hy8402ip mx_LIBS +=
Hy8401ip mx_LIBS += calc mx_LIBS += sscan
mx_LIBS_vxWorks +=
$(EPICS_BASE_IOC_LIBS)
#The following builds sncExample as a standalone
application #PROD_HOST += sncExample #sncExample_SNCFLAGS +=
+m #sncExample_SRCS += sncExample.stt #sncExample_LIBS += seq
pv #sncExample_LIBS +=
$(EPICS_BASE_HOST_LIBS)
include
$(TOP)/configure/RULES #---------------------------------------- #
ADD RULES AFTER THIS LINE
-----------------------------Error
mesg-------------------------------- ld < mx.munch sysAtReboot not
found. epicsExit will not be called by reboot. value = 516036768 =
0x1ec218a0
## Register all support components cd top value = 0 =
0x0 dbLoadDatabase("dbd/mx.dbd",0,0) value = 0 =
0x0 mx_registerRecordDeviceDriver(pdbbase) value = 0 = 0x0
motor dbLoadRecords("db/att.db") value = 0 =
0x0
MAXvSetup(1,16,0xF000,180,6,10) undefined symbol:
MAXvSetup
汪启胜 =================================================== No.239
Zhangheng Road PuDong District Shanghai Institute of Applied Physics
CAS Shanghai, China Tel: +86-21-33933256 Fax:
+86-21-33933031
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
Scanned by iCritical.
- MAXvSetup is an undefined symbol 汪启胜
Re: MAXvSetup is an undefined symbol Eric Norum
<2009>
<2009>
