Thank you for your answer.
I'd like to ask one more question:
Is it ok to break 40 chars limit in CALC field( or another text fields
like DESC) ?
I've changed this limit to 200 in calcoutRecord.dbd, db_access.c and
epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
2008/12/3, Kalantari Babak <[email protected]>:
> Hi,
> You do not need to write your own CA application for that.
> Monitor alarm status of your "ai" with a "calcout" record and write to
> your "bo" upon occurrence of the conditions.
> This can be done for example as the following:
> record(calcout, "$(ALGORITHM)")
> field(INPA,"$(YOUR_AI_REC).STAT CP") # monitoring
> field(INPB,"$(YOUR_BO_REC).VAL NPP")
> field(CALC, "A=3?1:A=5?0:B")
> field(OOPT, "On Change")
> field(OUT,"$(YOUR_BO_REC) PP")
> Alarm status value for HIHI is 3 and for LOLO is 5.
> HTH,
> Babak
- RE: How to implement simple control algorithm (one more question) Kalantari Babak
- RE: How to implement simple control algorithm (one more question) Dalesio, Leo
Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
<2008>
Re: Records not in Base Nicholas P. DiMonte
<2008>
