As is the nature of our profession just as you have mailed off a call
for help, one seems to find a solution.
I found that although I had done a make clean the iocpsc.db file that I
had created in the Db folder was not updated in the db folder after
make. So manually copying the file to the db folder curred the problem.
I could then initialize all my fields from the substitute file.
Maybe there is another param for the make process that would have
updated this file, as I said "make clean" didn't do the trick.
Many thanks anyway,
Ivan
iThemba LABS, SA
initial(init_value) rule within a field sometimes works ivan
Is it possible to implement a loop in db? ???
<2008>
<2008>
