thank you for your reply and help, following your guide, the problem mentioned in the last mail has been resolved. now, I come across a new problem as below: Cexp>dbgf ("R4IBT04:CISet") DBR_DOUBLE: 0 0x00000000 (0) Cexp>dbtr("R4IBT04:CISet") ACKS: INVALID ACKT: YES ADEL: 0 ALST: 0 filename="../recGbl.c" line number=88 AOFF: -5.01 ASG: ASLO: 1.525902e-04 BKPT: 0x00 PV: R4IBT04:CISet dbtr(dbProcess) DESC: analog output record DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1 DOL:CONSTANT 0.000000000000000e+00 DRVH: 0 DRVL: 0 DTYP: PSC EGU: amps EGUF: 0 EGUL: 0 EOFF: 0 ESLO: 0 EVNT: 0 FLNK:CONSTANT 0 HHSV: NO_ALARM HIGH: 0 HIHI: 5 HOPR: 4.545455 HSV: NO_ALARM HYST: 0 INIT: 0 IVOA: Continue normally IVOV: 0 LALM: 0 LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV: NO_ALARM LOLO: -5 LOPR: -4.545455 LOW: 0 LSV: NO_ALARM MDEL: 0 MLST: 0 NAME: R4IBT04:CISet NSEV: NO_ALARM NSTA: NO_ALARM OIF: Full OMOD: 0 OMSL: supervisory ORAW: 32833 ORBV: 1062 OROC: 0 OUT:VME_IO #C1 S0 @SPT OVAL: 0 PACT: 0 PHAS: 0 PINI: NO PREC: 3 PRIO: LOW PROC: 0 PUTF: 0 PVAL: 0 RBV: 1062 ROFF: 0 RPRO: 0 RVAL: 32833 SCAN: Passive SDIS:CONSTANT 0.000000000000000e+00 SEVR: INVALID SIML:CONSTANT 0.000000000000000e+00 SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT 0.000000000000000e+00 STAT: READ TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 1 VAL: 0 0x00000000 (0) Cexp>dbpf ("R4IBT04:CISet", "2.0") 0xffffffff (-1) filename="../dbTest.c" line number=365 dbPutField error I guess something is wrong when the record "R4IBT04:CISet" calls device support write_ao which calls driver support, I don't know how to solve it. thank you again! Haoli Shi Andrew Johnson 写: On Wednesday 17 December 2008 07:54:55 Shi HaoLi wrote:
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
