Subject: Re: ao record downloading error
To: [email protected]
Date: Wed, 17 Dec 2008 09:30:02 -0600
On Wednesday 17 December 2008 07:54:55 Shi HaoLi wrote:
>     There is a problem while downloading an "ao" record which is used for a
> peripheral I/O device named "PSC", part of the downloading console is like
> this: (OS is RTEMS, and EPICS version is 3.14.6)
>     dbLoadRecords("../db/powersupply.db")
> 0x00000000 (0)
>     iocInit()
># Starting iocInit
> ###  EPICS IOC CORE built on Jan  9 2008
> ###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
># filename="../recGbl.c" line number=88
> Bad init_rec return value  PV: R4IBT04:CISet  ao: init_record
> 0x00000000 (0)
> iocInit: All initialization complete
This error message is generated by the ao record support when the device
support's init_record() routine returns any value other than 0 or 2; that's
all I can tell you based on your report.  You'll have to take a look at
the "PSC" device support for the ao record and work out why it's returning
something different, what it means and how to fix it.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: ao record downloading error Shi HaoLi
Prev: ao record downloading error Shi HaoLi
Next: Firewire (IEEE 1394) support for areaDetector Pedersen, UK (Ulrik)
Next: Re: ao record downloading error Shi HaoLi
