Subject: ao record downloading error
To: [email protected]
Date: Wed, 17 Dec 2008 21:54:55 +0800
Hi, all
   There is a problem while downloading an "ao" record which is used for a
peripheral I/O device named "PSC", part of the downloading console is like this:
(OS is RTEMS, and EPICS version is 3.14.6)
   dbLoadRecords("../db/powersupply.db")
0x00000000 (0)
   iocInit()
Starting iocInit
###  EPICS IOC CORE built on Jan  9 2008
###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
filename="../recGbl.c" line number=88
Bad init_rec return value  PV: R4IBT04:CISet  ao: init_record
0x00000000 (0)
iocInit: All initialization complete
and contents of "R4IBT04:CISet" is as follows:
record(ao,"R4IBT04:CISet") {
		field(DESC, "analog output record")
		field(SCAN, "Passive")
		field(DTYP, "PSC")
		field(OUT, "#C1 S0 @SPT")
		field(PINI, "NO")
		field(PHAS, "0")
		field(EVNT, "0")
		field(DISV, "1")
		field(SDIS, "0.000000000000000e+00")
		field(DISS, "NO_ALARM")
		field(PRIO, "LOW")
		field(FLNK, "0.000000000000000e+00")
		field(OROC, "0.0000000e+00")
		field(DOL, "0.000000000000000e+00")
		field(OMSL, "supervisory")
		field(OIF, "Full")
		field(PREC, "3")
		field(LINR, "NO CONVERSION")
		field(EGUF, "0.0000000e+00")
		field(EGUL, "0.0000000e+00")
		field(EGU, "amps")
		field(ESLO, "0.0000000e+00")
		field(EOFF, "0.0000000e+00")
		field(ASLO, "1.525902e-04")
		field(AOFF, "-5.010000e+00")
		field(DRVH, "0.0000000e+00")
		field(DRVL, "0.0000000e+00")
		field(HOPR, "4.545455e+00")
		field(LOPR, "-4.545455e+00")
		field(HIHI, "5.000000e+00")
		field(LOLO, "-5.000000e+00")
		field(HIGH, "0.0000000e+00")
		field(LOW, "0.0000000e+00")
		field(HHSV, "NO_ALARM")
		field(LLSV, "NO_ALARM")
		field(HSV, "NO_ALARM")
		field(LSV, "NO_ALARM")
		field(HYST, "0.000000000000000e+00")
		field(ADEL, "0.000000000000000e+00")
		field(MDEL, "0.000000000000000e+00")
		field(SIOL, "0.000000000000000e+00")
		field(SIML, "0.000000000000000e+00")
		field(SIMS, "NO_ALARM")
		field(IVOA, "Continue normally")
		field(IVOV, "0.000000000000000e+00")}
any help is appreciated, thanks a lot!
Haoli Shi
Re: ao record downloading error Andrew Johnson
Prev: Re: Problems getting edm functional on NetBSD David Dudley
Next: Re: ao record downloading error Andrew Johnson
Prev: RE: Question on signals with Linux Mark Rivers
