Subject: Re: lockset question
Cc: [email protected]
Date: Fri, 12 Dec 2008 14:45:54 -0500
This was a long time ago but I think the problem was that on some architectures it was possible to get a bad value because reading a double is not an atomic operation.
Marty Kraimer
Andrew Johnson wrote:
On Thursday 11 December 2008 00:39:31 Till Straumann wrote:
Quoting the AppDevGuide (3.14.8, 3.14.10,
Section 5.4 "Database Locking")
"All records linked via OUTLINKs and FWDLINKs
 are placed in the same lock set.
 Records linked via INLINKs with PROCESS_PASSIVE
 or MAXIMIZE_SEVERITY TRUE are also forced to
 be in the same lock set."
I was naively concluding that records linked
via INLINK NPP NMS would _not_ be forced to be
I didn't, but I just did the research. The change occurred due to a commit to src/db/dbLock.c between the R3-14-0-alpha-1 and R3-14-0-alpha-2 releases:
revision 1.29
date: 2001-04-05 14:56:22 +0000;  author: mrk;  state: Exp;  lines: +76 -46;
add dbLockShowLocked
even scalar DB_LINKs forced into lock set
That commit included the following change in the code that calculates the initial lockset configuration (with at least one other similar deletion elsewhere in the file):
@@ -369,16 +363,6 @@ void epicsShareAPI dbLockInitRecords(dbB
                 plink = (DBLINK *)((char *)precord + pdbFldDes->offset);
                 if(plink->type != DB_LINK) continue;
                 pdbAddr = (DBADDR *)(plink->value.pv_link.pvt);
-                /* The current record is in a different lockset -IF-
-                *    1. Input link
-                *    2. Not Process Passive
-                *    3. Not Maximize Severity
-                *    4. Not An Array Operation - single element only
-                if (pdbFldDes->field_type==DBF_INLINK
-                && !(plink->value.pv_link.pvlMask&pvlOptPP)
-                && !(plink->value.pv_link.pvlMask&pvlOptMS)
-                && pdbAddr->no_elements<=1) continue;
                 dbLockSetMerge(precord,pdbAddr->precord);
The original behavior is not really a good idea because it allows a value to be fetched from another record while that record is active. While this may work in most circumstances, there are cases where it breaks because reading and/or writing the field value isn't an atomic operation, so the read can return mangled data:
1. If the field being copied is a string,
2. If the CPU uses software floating point,
3. On SMP machines if the field crosses a cache-line boundary.
The rules for many SMP machines actually require a write + read barrier to guarantee that the reading CPU sees data that was written by another CPU, and the only portable way of inserting those barriers is with a mutex, which is what a lockset provides.
At this point I think the only reasonable fix is to update the documentation, and tell people to use a .CA link to break a lockset. Local .CA links do not traverse the network, so they're not quite as inefficient as they might seem. Unfortunately this can break some R3.13 IOCs that get converted to R3.14, but I don't see any way around that issue; any IOC developer doing a conversion will have to look carefully at their locksets if they matter to that IOC.
- Andrew
lockset question Till Straumann
Re: lockset question Andrew Johnson
Prev: Re: lockset question Andrew Johnson
Next: Problems getting edm functional on NetBSD David Dudley
Next: Question about WebCA Bao Chunlei
