Subject: Re: Support for shell variables in the EPICS build system
To: Remi Machet <[email protected]>
Cc: "Ernest L. Williams Jr." <[email protected]>, [email protected]
Date: Tue, 9 Dec 2008 16:56:49 -0600
On Tuesday 09 December 2008 15:56:34 Remi Machet wrote:
> I am used to work on multiple projects at the same time and I have seen
> over the years that even on a single project, having multiple 'views' of
> a software can increase quite a lot productivity (like a base with extra
> printf and one other clean). I am trying to setup an EPICS environment
> that can do exactly that for myself.
You can turn off the checkRelease process for a module if you want it to be
able to use a different support module than any related modules are using
directly, such as switching to a different version of Base.  To do that edit
the module's configure/Makefile and set CHECK_RELEASE to NO, change the
configure/RELEASE file (or any file it includes) as needed, and then do
a 'make rebuild' from the top directory of the module.
> I would suggest modifying convertRelease.pl to at least explicitly
> refuse using environment variables (ie : display an error message when
> one is found), because it can get extremely confusing for newbies (right
> now the variable is just replaced by '').
The following patch to Base will cause convertRelease.pl to output a warning
whenever it attempts to expand an undefined variable.  If this helps I think
it would be a worthwhile change to include -- thanks for the suggestion.
Index: src/tools/EPICS/Release.pm
--- src/tools/EPICS/Release.pm    29 Aug 2008 21:06:56 -0000      1.1.2.2
+++ src/tools/EPICS/Release.pm    9 Dec 2008 22:36:37 -0000
@@ -84,6 +84,8 @@ sub expandRelease {
     while (my ($macro, $path) = each %$Rmacros) {
         while (my ($pre,$var,$post) = $path =~ m/(.*)\$\((\w+?)\)(.*)/) {
+            warn "Undefined macro \$($var) used in RELEASE file\n"
+                unless exists $Rmacros->{$var};
             $path = $pre . $Rmacros->{$var} . $post;
             $Rmacros->{$macro} = $path;
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Support for shell variables in the EPICS build system Remi Machet
Re: Support for shell variables in the EPICS build system Andrew Johnson
Re: Support for shell variables in the EPICS build system Remi Machet
Prev: Re: Support for shell variables in the EPICS build system Remi Machet
Next: lockset question Till Straumann
Next: Video solutions Terry Carlino
