Subject: DeltaTau UMAC ethernet access?
To: tech-talk <[email protected]>
Date: Tue, 09 Dec 2008 15:05:17 +0100
Hi all,
Is there a driver for the DeltaTau UMAC ethernet interface?
I could only find drivers for VME based or PCI based PMAC controllers but not for controllers (Turbo PMAC 2 CPU) connected via ethernet or USB. The protocol seems to be the same as for other DeltaTau controller types, only the data transfer layer is different (uses UDP). A typical case for asynOctet, I think.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: DeltaTau UMAC ethernet access? Rees, NP (Nick)
Prev: Re: ioc running on a server with a private network Dirk Zimoch
Next: RE: DeltaTau UMAC ethernet access? Rees, NP (Nick)
