Subject: RE: How to implement simple control algorithm (one more question)
To: "Ilya V. Kitaev" <[email protected]>
Cc: [email protected]
Date: Fri, 5 Dec 2008 11:27:37 +0100
I do not have a precise answer to this question, maybe others can
comment on it.
What might be a disadvantage is that you have to take care of your
customization whenever you try your database with other EPICS versions
(e.g. upgrade) and therefore your database would have a problem to work
with a normal ("standard") EPICS distribution.
Babak
> -----Original Message-----
> From: Ilya V. Kitaev [mailto:[email protected]]
> Sent: Freitag, 5. Dezember 2008 09:29
> Hi,
> Thank you for your answer.
> I'd like to ask one more question:
> Is it ok to break 40 chars limit in CALC field( or another text fields
> like DESC) ?
> I've changed this limit  to 200 in calcoutRecord.dbd, db_access.c and
> epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
Re: How to implement simple control algorithm (one more question) Ralph Lange
Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
Prev: Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
Next: Re: How to implement simple control algorithm (one more question) Ralph Lange
