Subject: compile error about gateway
To: "tech-talk" <[email protected]>
Date: Wed, 3 Dec 2008 15:39:49 +0800
hi, all:
I think I would disturb Dirk to see thsi again. :)
when I tried to compile gateway2_0_2_1 on centOS 5.2, there is an error like following:
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/usr/local/epics/extensions/src/gateway2_0_2_0/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM      -g  -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../base/include/os/Linux -I../../../../base/include -I../../../include/os/Linux -I../../../include     -I../../../../base/src/cas/generic    ../gateVc.cc
../../../../base/include/gddUtils.h:85: warning: 'class gddDestructor' has virtual functions but non-virtual destructor
../../../../base/include/gddUtils.h: In member function 'char* gddDestructor::newdel_next()':
../../../../base/include/gddUtils.h:96: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddUtils.h: In member function 'void gddDestructor::newdel_setNext(char*)':
../../../../base/include/gddUtils.h: In member function 'char* gddBounds1D::newdel_next()':
../../../../base/include/gddUtils.h:117: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddUtils.h: In member function 'void gddBounds1D::newdel_setNext(char*)':
../../../../base/include/gddUtils.h: In member function 'char* gddBounds2D::newdel_next()':
../../../../base/include/gddUtils.h:129: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddUtils.h: In member function 'void gddBounds2D::newdel_setNext(char*)':
../../../../base/include/gddUtils.h: In member function 'char* gddBounds3D::newdel_next()':
../../../../base/include/gddUtils.h:141: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddUtils.h: In member function 'void gddBounds3D::newdel_setNext(char*)':
../../../../base/include/gdd.h: In member function 'char* gdd::newdel_next()':
../../../../base/include/gdd.h:468: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gdd.h: In member function 'void gdd::newdel_setNext(char*)':
../../../../base/include/gddI.h: In member function 'void gdd::setStat(aitUint16)':
../../../../base/include/gddI.h:106: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddI.h: In member function 'void gdd::setSevr(aitUint16)':
../../../../base/include/gddI.h:108: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddI.h: In member function 'aitUint16 gdd::getStat() const':
../../../../base/include/gddI.h:110: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/gddI.h: In member function 'aitUint16 gdd::getSevr() const':
../../../../base/include/gddI.h:112: warning: dereferencing type-punned pointer will break strict-aliasing rules
../../../../base/include/fdManager.h: At global scope:
../../../../base/include/fdManager.h:39: warning: 'class fdRegId' has virtual functions but non-virtual destructor
../../../../base/include/gddAppTable.h:65: warning: 'class gddApplicationTypeDestructor' has virtual functions but non-virtual destructor
../gateVc.cc: In member function 'virtual caStatus gateVcData::read(const casCtx&, gdd&)':
../gateVc.cc:1013: error: 'AlignedWireRef' was not declared in this scope
../gateVc.cc:1013: error: expected primary-expression before '>' token
make[1]: *** [gateVc.o] Error 1
make[1]: Leaving directory `/usr/local/epics/extensions/src/gateway2_0_2_0/O.linux-x86'
make: *** [install.linux-x86] Error 2
If I comment out that line "ca_uint16_t caProtoMask = AlignedWireRef < epicsUInt16 >(pMonInfo->m_mask);" , it can pass, why?
On fedora core, gateway could be compiled. Can anyone give me some help? thanks a lot in advance
Best regards
Geyang  2008-12-03
Re: compile error about gateway Dirk Zimoch
Prev: Re:RE: Epics error exiting softIOC. marco_hair
Next: Re: Epics error exiting softIOC. Ralph Lange
Prev: Re: Re: Epics error exiting softIOC. Silver
Next: Re: compile error about gateway Dirk Zimoch
