Seems this problem is still there. I am using CentOS5, base3.14.8. ps, would you please tell me how to see that "Mantis entry" ? thank you very much. Best wishes, Geyang 2008/12/3 在2006-10-19,"Jeff Hill" <[email protected]> 写道: > >In September I committed changes to the log client code related to Mantis >entry 269. When I was testing that change I did observe some shutdown >anomalies with the log client which I committed a fix for also. > >So I suspect, but can't easily confirm, that your bug has already been >fixed. > >Jeff > >> -----Original Message----- >> From: MacKenzie, Ronald R. [mailto:[email protected]] >> Sent: Wednesday, October 18, 2006 1:34 PM >> To: [email protected] >> Cc: Spencer, Nancy >> Subject: Epics error exiting softIOC. >> >> Hi All, >> >> When we exit a softIOC, we get the following message. >> Has anyone else seen it? >> >> > epics>exit >> > epicsMutex pthread_mutex_destroy failed: error Device or resource busy >> >> The suspicion is that it's coming from iocLogClient >> >> Environment: >> Epics 3.14.8.2 >> Gcc 3.2.3 >> Linux RH 3. >> >> Cheers, >> Ron MacKenzie >> >> -- >> 650-926-2490 >> http://www.slac.stanford.edu/~ronm/ > [广告] 重奖 悬赏kfc3v3 球衣
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
