I am getting the following error from autosave version 4-4: ========================================================== create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM1:motor") 0x00000000 (0) create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM1:motor") 0x00000000 (0) create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM2:motor") save_restore:create_data_set: 'motor_positions.req' already in c mode0xffffffff (-1) create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM2:motor") save_restore:create_data_set: 'motor_settings.req' already in c mode0xffffffff (-1) create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM3:motor") save_restore:create_data_set: 'motor_positions.req' already in c mode0xffffffff (-1) create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM3:motor") save_restore:create_data_set: 'motor_settings.req' already in c mode0xffffffff (-1) ================================================================ I guess this means that it is not reentrant like the sequencer? In any case, we will do the request file like this: ========= motor_positions.req ================= $(P):CM1:motor.DVAL $(P):CM1:motor.OFF $(P):CM2:motor.DVAL $(P):CM2:motor.OFF $(P):CM3:motor.DVAL $(P):CM3:motor.OFF ==========================================
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
