Subject: Re: A bug of calc record?
To: [email protected]
Date: Sun, 23 Nov 2008 21:55:27 -0600
This is not actually a problem. 1.38777878078145e-16 is an excellent
approximation to the desired value of zero, and an excellent approximation
is the best you can ever hope for, with finite-precision arithmetic.
You're accumulating round-off error each time you add or subtract 0.1.
You could set PREC to, say, 6, and clients would only show 6 digits
of the result.  (I don't know right off if dbpr honors PREC, but it's
just a diagnostic routine, so it won't usually matter.)
Silver wrote:
> hi, all:
> I am trying to use the record suggested by Ned Arnold. It's good work when
> increment is 1. but when I change to 0.1, it has a strange problem. the db
> file is like following:
> record(ai, "$(user):aiExample") { field(DESC, "Analog input") field(INP,
> "$(user):calcExample.VAL  NPP NMS") } record(calc, "$(user):calcExample") {
> field(DESC, "Counter") field(SCAN,"1 second") field(FLNK,
> "$(user):aiExample") field(CALC, "A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1")
> field(INPA, "$(user):calcExample.VAL  NPP NMS") field(INPB,
> "$(user):calcExample.LA NPP NMS") field(EGU, "Counts") }
> Following is dbtr message, we can see when the value change to 0.1, after
> caculation, it's value change to VAL: 1.38777878078145e-16, can anyone give
> some suggestion? thanks a lot in advance.
> epics> dbtr tcl:calcExample A: 0.2              ACKS: NO_ALARM      ACKT: YES
> ADEL: 0 ALST: 0.1           ASG:                B: 0.3              BKPT:
> 0x00 C: 0                CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
>  D: 0                DESC: Counter       DISA: 0             DISP: 0
>  DISS: NO_ALARM      DISV: 1             DTYP: <nil>         E: 0
>  EGU: Counts         EVNT: 0             F: 0 FLNK:DB_LINK tcl:aiExample
> G: 0                H: 0 HHSV: NO_ALARM      HIGH: 0             HIHI: 0
> HOPR: 0 HSV: NO_ALARM       HYST: 0             I: 0 INPA:DB_LINK
> tcl:calcExample.VAL NPP NMS INPB:DB_LINK tcl:calcExample.LA NPP NMS
> INPC:CONSTANT       INPD:CONSTANT INPE:CONSTANT       INPF:CONSTANT
> INPG:CONSTANT       INPH:CONSTANT INPI:CONSTANT       INPJ:CONSTANT
> INPK:CONSTANT       INPL:CONSTANT J: 0                K: 0                L:
> 0                LA: 0.2 LALM: 0.1           LB: 0.3             LC: 0
> LCNT: 0 LD: 0               LE: 0               LF: 0               LG: 0
>  LH: 0               LI: 0               LJ: 0               LK: 0
>  LL: 0               LLSV: NO_ALARM      LOLO: 0             LOPR: 0
>  LOW: 0              LSV: NO_ALARM       MDEL: 0             MLST: 0.1
>  NAME: tcl:calcExample                   NSEV: NO_ALARM      NSTA: NO_ALARM
>  PACT: 0             PHAS: 0             PINI: NO            PREC: 0
>  PRIO: LOW           PROC: 0             PUTF: 0             RPRO: 0
>  SCAN: 1 second      SDIS:CONSTANT       SEVR: NO_ALARM      STAT: NO_ALARM
>  TPRO: 0             TSE: 0              TSEL:CONSTANT       UDF: 0
>  VAL: 0.1 epics> dbtr tcl:calcExample A: 0.1              ACKS: NO_ALARM
> ACKT: YES           ADEL: 0 ALST: 1.38777878078145e-16              ASG:
> B: 0.2 BKPT: 0x00          C: 0 CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
> D: 0 DESC: Counter       DISA: 0             DISP: 0             DISS:
> NO_ALARM DISV: 1             DTYP: <nil>         E: 0                EGU:
>  HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
>  I: 0                INPA:DB_LINK tcl:calcExample.VAL NPP NMS
>  INPB:DB_LINK tcl:calcExample.LA NPP NMS INPC:CONSTANT       INPD:CONSTANT
>  INPE:CONSTANT       INPF:CONSTANT       INPG:CONSTANT       INPH:CONSTANT
>  INPI:CONSTANT       INPJ:CONSTANT       INPK:CONSTANT       INPL:CONSTANT
>  J: 0                K: 0                L: 0                LA: 0.1
>  LALM: 1.38777878078145e-16              LB: 0.2             LC: 0
>  LG: 0               LH: 0               LI: 0               LJ: 0
>  LK: 0               LL: 0               LLSV: NO_ALARM      LOLO: 0
>  LOPR: 0             LOW: 0              LSV: NO_ALARM       MDEL: 0
>  MLST: 1.38777878078145e-16              NAME: tcl:calcExample
>  NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0             PHAS: 0
>  PINI: NO            PREC: 0             PRIO: LOW           PROC: 0
>  PUTF: 0             RPRO: 0             SCAN: 1 second      SDIS:CONSTANT
>  SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0             TSE: 0
>  TSEL:CONSTANT       UDF: 0              VAL: 1.38777878078145e-16
>  epics> dbtr tcl:calcExample A: 1.38777878078145e-16                 ACKS:
> NO_ALARM      ACKT: YES ADEL: 0             ALST: 0.1           ASG:
> B: 0.1 BKPT: 0x00          C: 0 CALC: A-B>0?A>=0.9?0.8:A+0.1:A<0.1?0.1:A-0.1
>  J: 0                K: 0                L: 0 LA: 1.38777878078145e-16
> LALM: 0.1           LB: 0.1 LC: 0               LCNT: 0             LD: 0
> LE: 0 LF: 0               LG: 0               LH: 0               LI: 0
>  LJ: 0               LK: 0               LL: 0               LLSV: NO_ALARM
>  LOLO: 0             LOPR: 0             LOW: 0              LSV: NO_ALARM
>  MDEL: 0             MLST: 0.1           NAME: tcl:calcExample
>  TSEL:CONSTANT       UDF: 0              VAL: 0.1 epics>
> Best regards Geyang  2008-11-23
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: A bug of calc record? Dirk Zimoch
A bug of calc record? Silver
Prev: A bug of calc record? Silver
Next: Re: Working with sequencer Benjamin Franksen
Next: Re: A bug of calc record? Dirk Zimoch
