Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
To: haquin <[email protected]>
Cc: [email protected]
Date: Thu, 20 Nov 2008 11:16:38 -0600
Hi Christophe,
On Thursday 20 November 2008 10:49:18 haquin wrote:
> We are in the following config:
> - vxWorks 6.5
> - MPC 7457 processor
> - MVME5500 -0161
> - BSP version 2.0/4
> The epics target is vxWorks-mvme5500
> I didn't modified the source code of the R3.14.9,
> I still have to check it has not been modified by someone else,
> I keep you informed about this point.
The vxWorks-mvme5500 target architecture is not one that ships with EPICS
Base.  Can you try building and using the vxWorks-ppc604_long architecture
instead (which is the official target for that processor) and see if the
problem still occurs?  If not, you'll have to post the configuration files
you're using for that target (base/configure/os/*vxWorks-mvme5500*) for me to
help any further.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Prev: RE: Fast Cross-IOC Loops? Thompson, David H.
Next: Re: CAEN V965 driver Kate Feng
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
