Hi Andew,
We are in the following config:
- vxWorks 6.5
- MPC 7457 processor
- MVME5500 -0161
- BSP version 2.0/4
The epics target is vxWorks-mvme5500
I didn't modified the source code of the R3.14.9,
I still have to check it has not been modified by someone else,
I keep you informed about this point.
Regards.
Andrew Johnson a Ãcrit :
Hi Christophe,
On Monday 17 November 2008 02:58:09 haquin wrote:
We've just realized that my IOC was running under VxWorks !
So I restarted the SAME IOC but under linux-x86 and then all is working
correctly.
Here is the difference you are looking for, the problem occur under
VxWorks.
I've just tried this with a couple of vxWorks IOCs (both vxWorks-ppc604_long
and vxWorks-68040) on both R3.14.9 and R3.14.10 and I don't see the bug
occurring:
tux% caput -c anj:aiExample.DESC "New string"
Old : anj:aiExample.DESC Analog input
New : anj:aiExample.DESC New string
tux% caput -c -s -a anj:aiExample.DESC 1 "Array string"
Old : anj:aiExample.DESC New string
New : anj:aiExample.DESC Array string
tux% caput -c -s -a anj:aiExample.DESC 2 Array string
Old : anj:aiExample.DESC Array string
Write callback operation timed out
What version of vxWorks are you running, on what CPU, and what epics target
architecture are you using for the IOC? Have you made any modifications to
the R3.14.9 source code at all?
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
- USE of CA lib: problem using ca_array_put_callback with strings haquin
- Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: A db question about aiExample Ned Arnold
RE: Fast Cross-IOC Loops? Thompson, David H.
<2008>
<2008>
