Subject: Re: A db question about aiExample
To: marco_hair <[email protected]>
Date: Thu, 20 Nov 2008 08:49:37 -0600
Geyang -
Changing the definition of the calc record to this (only the CALC and INPB field are different) will give you the desired result:
record(calc, "$(user):calcExample")
        field(DESC, "Counter")
        field(SCAN,"1 second")
        field(FLNK, "$(user):aiExample")
        field(CALC, "A-B>0?A=9?8:A+1:A=0?1:A-1")
        field(INPA, "$(user):calcExample.VAL  NPP NMS")
        field(INPB, "$(user):calcExample.LA NPP NMS")
        field(EGU, "Counts")
        field(HOPR, "10")
        field(HIHI, "8")
        field(HIGH, "6")
        field(LOW, "4")
        field(LOLO, "2")
        field(HHSV, "MAJOR")
        field(HSV, "MINOR")
        field(LSV, "MINOR")
        field(LLSV, "MAJOR")
   Ned
On Nov 20, 2008, at 4:57 AM, marco_hair wrote:
Dear all:
  in the aiExample.db coming with soft ioc template,
record(ai, "$(user):aiExample")
field(DESC, "Analog input")
field(INP, "$(user):calcExample.VAL  NPP NMS")
field(EGUF, "10")
field(HOPR, "10")
field(LOPR, "0")
field(HIHI, "8")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(CALC, "(A<B)?(A+C):D")
field(INPB, "9")
field(INPC, "1")
field(INPD, "0")
field(HOPR, "10")
field(HIHI, "8")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HSV, "MINOR")
field(LSV, "MINOR")
the ai value will change from 0-9 and then loop from 0 again.
if I want to generate the value from 0-9, then decrease it, such as 9-0. That is, the value increase from 0-9, then decrease from 9-0 one by one, how can I written it?
Thanks a lot for your help.
Best wishes
Geyang 2008/11/20
[广告] 金秋最关注楼盘-房不胜房
Re: Re: A db question about aiExample Silver
A db question about aiExample marco_hair
Prev: Re: A db question about aiExample Benjamin Franksen
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: Re: A db question about aiExample Silver
