Hi Christophe,
On Monday 17 November 2008 02:58:09 haquin wrote:
> We've just realized that my IOC was running under VxWorks !
> So I restarted the SAME IOC but under linux-x86 and then all is working
> correctly.
> Here is the difference you are looking for, the problem occur under
> VxWorks.
I've just tried this with a couple of vxWorks IOCs (both vxWorks-ppc604_long
and vxWorks-68040) on both R3.14.9 and R3.14.10 and I don't see the bug
occurring:
tux% caput -c anj:aiExample.DESC "New string"
Old : anj:aiExample.DESC Analog input
New : anj:aiExample.DESC New string
tux% caput -c -s -a anj:aiExample.DESC 1 "Array string"
Old : anj:aiExample.DESC New string
New : anj:aiExample.DESC Array string
tux% caput -c -s -a anj:aiExample.DESC 2 Array string
Old : anj:aiExample.DESC Array string
Write callback operation timed out
What version of vxWorks are you running, on what CPU, and what epics target
architecture are you using for the IOC? Have you made any modifications to
the R3.14.9 source code at all?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
- USE of CA lib: problem using ca_array_put_callback with strings haquin
- Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Re: IOC Shell Eric Norum
Re: Building system with Debug Andrew Johnson
<2008>
<2008>
