the gensubs header has a 'not' field thats a c++ reserved keyword.
rename the field in the header, or give gcc -fno-operator-names
Pierrick Hanlet wrote:
I have a problem with genSubRecord.h when compiling my code as
C++ source instead of C. I've stripped everything out of the code,
except for header files, and empty functions and called the source file
either "test.c" or "test.cc". In my source directory, I've modified the
Makefile to use the source test.c or test.cc (I've also deleted the other
source file in the directory).
When the Makefile uses test.c, there are no compilation errors.
However, when the Makefile uses test.cc, then I get the following
compilation errors:
../../include -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include ../test.cc
../../../include/genSubRecord.h:185: error: expected unqualified-id before ‘!’ token
make[3]: *** [test.o] Error 1
make[3]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp'
make: *** [tgtMonApp.install] Error 2
Any ideas on how to proceed?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- C++ and genSubRecord.h Pierrick Hanlet
Re: C++ and genSubRecord.h Eric Norum
Fast Cross-IOC Loops? Ralph Lange
<2008>
<2008>
