Without changing the field names I don't see how C++ is going to work.
The line in question is:
epicsUInt32 not; /* No. in T */
And 'not' is a C++ keyword.
On Nov 11, 2008, at 10:34 AM, Pierrick Hanlet wrote:
I have a problem with genSubRecord.h when compiling my code as
C++ source instead of C. I've stripped everything out of the code,
except for header files, and empty functions and called the source
file
either "test.c" or "test.cc". In my source directory, I've
modified the
Makefile to use the source test.c or test.cc (I've also deleted the
other
source file in the directory).
When the Makefile uses test.c, there are no compilation errors.
However, when the Makefile uses test.cc, then I get the following
compilation errors:
../../include -I/usr/local/epics/base/include/os/Linux -I/usr/local/
epics/base/include ../test.cc
../../../include/genSubRecord.h:185: error: expected unqualified-id
before ‘!’ token
make[3]: *** [test.o] Error 1
make[3]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src/
O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/hanlet/epics/tgtMon/tgtMonApp'
make: *** [tgtMonApp.install] Error 2
Any ideas on how to proceed?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- C++ and genSubRecord.h Pierrick Hanlet
Re: C++ and genSubRecord.h Matthieu Bec
<2008>
<2008>
