I am facing the following problem. I try to compile msi 1.4 using base 3.14.10. I get the following crash. make -C ./msi1_4 install make[1]: Entering directory `<EPICS Extension Dir>/src/msi1_4' make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[2]: Entering directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86' /usr/bin/gcc-3.4 -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../base-3.14.10/include/os/Linux -I../../../../base-3.14.10/include -I../../../include ../msi.c ../msi.c: In function `main': ../msi.c:69: error: `TRUE' undeclared (first use in this function) ../msi.c:69: error: (Each undeclared identifier is reported only once ../msi.c:69: error: for each function it appears in.) ../msi.c:86: error: `FALSE' undeclared (first use in this function) ../msi.c: In function `makeSubstitutions': ../msi.c:167: error: `TRUE' undeclared (first use in this function) ../msi.c:225: error: `FALSE' undeclared (first use in this function) ../msi.c: In function `inputAddPath': ../msi.c:298: error: `TRUE' undeclared (first use in this function) ../msi.c:298: error: `FALSE' undeclared (first use in this function) ../msi.c: In function `freePattern': ../msi.c:506: error: `FALSE' undeclared (first use in this function) ../msi.c: In function `substituteGetNextSet': ../msi.c:551: error: `FALSE' undeclared (first use in this function) ../msi.c:553: error: `TRUE' undeclared (first use in this function) ../msi.c: In function `substituteGetReplacements': ../msi.c:616: error: `FALSE' undeclared (first use in this function) ../msi.c:630: error: `TRUE' undeclared (first use in this function) ../msi.c: At top level: ../msi.c:487: warning: 'freeSubFile' defined but not used make[2]: *** [msi.o] Error 1 make[2]: Leaving directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86' make[1]: *** [install.linux-x86] Error 2 make[1]: Leaving directory `<EPICS Extension Dir>/src/msi1_4' make: *** [msi1_4.install] Error 2 My system is a debian sarge (3.1) clone using gcc3.4 and gmake 3.81. Any idea? Hints would be appreciated. Compiling the same code against 3.14.9 succeeds. Best regards, Peter -- Dr. rer. nat. Peter W. Zumbruch EE - department / Controls group / GSI E-Mail: P.Zumbruch_at_gsi.de Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986 GSI Helmholtzzentrum für Schwerionenforschung GmbH Planckstraße 1 / D-64291 Darmstadt / www.gsi.de Gesellschaft mit beschränkter Haftung Sitz der Gesellschaft: Darmstadt Handelsregister: Amtsgericht Darmstadt, HRB 1528 Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph, Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
