Hello Wantianin,
> bad request code=13 in DG
Request code 13 is a CA beacon message. I suspect that the UDP daemon of
this CA server (the CA server is a sub-component of your gateway) is
configured to listen on the wrong UDP port. Typically the CA UDP daemon
listens for search messages on port 5064, and the CA repeater daemon listens
for IOC beacon messages on port 5065.
The CA gateway configuration, due to its encapsulating both a CA server and
a CA client, is without doubt more difficult to set up correctly. You might
try sending a description of your situation, and how you have set your CA
environment variables to tech-talk where there are many experience persons
who can provide assistance.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of ???
> Sent: Sunday, November 09, 2008 8:22 PM
> To: tech-talk
> Subject: question about ca gateway
> hi all,
> I have meet a strange question about ca gateway, in our situation,
ca
> gateway is running on a workstation , a softioc (use makeBaseApp.pl to
> create ) is running on a machine in the same subnet, the ca gateway will
> display the following error message and then the corresponding pv can not
> be get from the ca gateway. it seems that the ioc send some udp package to
> the ca gateway which cause the error occurs. when this ioc is running,
the
> error will occurs continually, if restart the ca gateway ,we can get pv
> for a few seconds and then fails again. before start the ioc, if we set
the
> environment variable "EPICS_CAS_INTF_ADDR_LIST=127.0.0.1" or set some
> other environment variable to let the ioc not to send message to ca
> gateway ,the error will not occur,
> Is there some way of solve this problem? ps: I notice that only when the
> ioc is complied use base3.14.9(if recompile the ca gateway in base 3.14.9
> the problem still occurs),and if the ioc is compiled use 3.14.8.2 the
> problem will not occur.
> error message:
> CAS: CAS Request: ? on 10.30.50.13:32920: cmd=13 cid=11 typ=11 cnt=5080
> psz=0 avail=a1e320d
> Nov 03 10:00:00 !!! Errlog message received (message is above)
> filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
> protocol from client was invalid unexpected problem with UDP input from
> "10.30.50.13:32920"
> psz=0 avail=a1e320d
> Nov 03 10:00:01 !!! Errlog message received (message is above)
> "10.30.50.13:32920"
> psz=0 avail=a1e320d
> thanks a lot,
> wantianin
- question about ca gateway 万天敏
Re: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
<2008>
Re: question about ca gateway Dirk Zimoch
<2008>
