Subject: Re: Problem with LabVIEW Shared Memory Interface to EPICS IOC
To: "EPICS tech-talk" <[email protected]>
Date: Mon, 10 Nov 2008 07:46:55 +0100
Solution:
- It is necessary to install all software parts to drive C: with default
installation pathes, since absolute pathes are used.
- You need to use a _decimal point_ in LabVIEW. Otherwise you get erros when
the EPICS IOC loads the database.
Regards Holger
____________________________
Experiment Elektronik/Kontrollsysteme
Dr. rer. nat. Holger Brand
Tel: +49 6159 71 2123
Fax: +49 6159 71 2986
eMail: [email protected]
Web: www.gsi.de/controls
GnuPG: http://www.gnupg.de/
- Key-ID=D55871D3
- Fingerprint=9337 0701 0756 25C6 E920 1040 15FE 7936 D558 71D3
- PublicKey: http://wiki.gsi.de/cgi-bin/view/Personalpages/PublicKey
Diese eMail ist nicht sicher vor Vorratdatenspoeicherung!
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1
D-64291 Darmstadt
www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
-----Ursprüngliche Nachricht-----
Von: Brand, Holger
Gesendet: Dienstag, 28. Oktober 2008 09:55
An: EPICS tech-talk
Betreff: Problem with LabVIEW Shared Memory Interface to EPICS IOC
I encountered problems with the LabVIEW Shared Memory Interface to EPICS
IOC.
I downloaded and installed following packages:
- EPICS Shared Memory Ver 3.14.7
- Beta 2 Installer of SNS Template
I followed the instructions in "LabVIEW Shared Memory Interface.doc" Version
2.3 Beta June 2005.
I am using LabVIEW 8.5. I had to correct for some Path2String conversion and
then the Example VIs were executable. I also started the caRepeater.
Then I started the server VIs of the examples first. The EPICS IOC was
started successfully and "dbl" displayed the expected PVs. Next I started
the client Vis. I changed the "DAC" and "Coefficient" valued and could
observer that this vales were received and processed by the server VI. In
parallel I was monitoring the PVs using caMonitor.
The problem is that the value of the "ADC" PV is not updated, neither in the
LV client nor in the caMonitor process. The same is true for the "Readback"
values. Stopping the server VI and restarting (I killed the running IOC)
results in updating the "ADC" and "Readback" values once only.
I guess that there is a problem with triggering the record processing in the
IOC via SM.
Questions:
- Does anybody has an idea how to solve the problem?
- Is a released version (not beta status) of the software available? I did
not found any newer.
- Is a LabVIEW 8.x version for the LabVIEW libraries available?
Thanks Holger
GSI - Abteilung EE/KS
- Key-ID=D55871D3
GSI Helmholtzzentrum für Schwerionenforschung GmbH Planckstraße 1
D-64291 Darmstadt
www.gsi.de
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Prev: question about ca gateway 万天敏
Next: RE: question about ca gateway Jeff Hill
Prev: Problem with LabVIEW Shared Memory Interface to EPICS IOC Brand, Holger
Next: function-name collision in edm/calcPv and epics/libCom/calc Thomas Birke
