Subject: edm
To: "EPICS Techtalk" <[email protected]>
Date: Wed, 5 Nov 2008 14:32:22 -0800
I am trying to figure out how to simulate tabs behavior in an edm screen.  The attached image file shows an example of what I am trying to do.  The file moreCmnds.jpg shows a screen which consists of 5 message buttons and an embedded window.  The buttons communicate with the embedded window via a string type LOC PV.  When one of the buttons is pressed, it passes a file name of an edm display to be shown.  All that works well.  When one of the buttons is pressed, it becomes "active" until another button is pressed (or as long as the edm display it is associated with is showing in the embedded window).  I would like the "active" button to be highlighted, for instance by using a background color different from its "inactive" state.  Any suggestions on how to do that will be most appreciated.
Zen
Attachment: moreCmnds.jpg
Description: moreCmnds.jpg
Re: edm (tabs) Mathew James Hicks
Prev: base-3.14.10: CONFIG.Common.linuxCommon: CONFIG-SITE.Common.linuxCommon not called Peter Zumbruch
Next: Re: edm (tabs) Mathew James Hicks
Prev: EDM Szalata, Zenon M.
