On Nov 3, 2008, at 3:39 AM, Dirk Zimoch wrote:
Hi Zen,
ASCII is usually a quite inefficient encoding for huge waveforms.
Often devices offer a "raw" format, (e.g. 2 byte integer). This
format is not terminated because raw input may consist of CR LF
bytes. However, it has a fixed input length. Often is is prefixed by
a header that defines the input length. Unfortunately StreamDevice
cannot interpret this header. (This would be something for a asyn
interpose layer, I guess). But you can easily calculate the size
yourself. If the header looks like this "#800001000" the total input
size is 1010 (10+2*500). And you can use a format like this:
This format is an IEEE-488.2 standard. For an example of reading this
see the readArbitraryBlockProgramData() function in the ASYN devGpib
support (modules/soft/asyn/asyn/devGpib/devSupportGpib.c).
For an example of this function's use see the Tektronix TDS3000/5000
support (modules/instrument/tds3000/TDS3000/src/devTDS.c).
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- GPIB - asyn - streamdevice Szalata, Zenon M.
- Re: GPIB - asyn - streamdevice Dirk Zimoch
EDM cursors GOURNAY Jean-Francois
<2008>
how to load several same devices in stream marco_hair
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
