First of all, it does not make much sense to read that array as a huge string with StreamDevice and then to use a genSub to convert it to float. StreamDevice has been designed to do conversions. Please see the StreamDevice documentation for waveform records. Then, when reading without InTerminator (and probably a short ReadTimeout) any interruption in the input is "end of string". Such interruptions may occur because the GPIB data stream is wrapped into packages for IP transfer and long arrays may need two or more packages. In principle, StreamDevice together with asynDriver implements a "atomic" transfer. The communication port is locked until the transfer is done. But with InTerminator="", you tell the system: "Whenever input is a bit late, then the transfer is done. You say the data is ASCII coded floating point. In that format, it is usually terminated properly and separated by comma. Then, the protocol should look like this: rTDCh12 { Separator=","; out "TRAC:SOUR CH\$1;:TRAC\$1:INDEX 1;:TRAC\$1:AVER:DATA?"; in "%f"; } The waveform should be of type DOUBLE or FLOAT. The %f in the format is repeated until no further input is found or until NELM points have been read, whatever occurs first. NORD is set accordingly. ASCII is usually a quite inefficient encoding for huge waveforms. Often devices offer a "raw" format, (e.g. 2 byte integer). This format is not terminated because raw input may consist of CR LF bytes. However, it has a fixed input length. Often is is prefixed by a header that defines the input length. Unfortunately StreamDevice cannot interpret this header. (This would be something for a asyn interpose layer, I guess). But you can easily calculate the size yourself. If the header looks like this "#800001000" the total input size is 1010 (10+2*500). And you can use a format like this: InTerminator=""; MaxInput=1010; in "#800001000%2r"; The waveform should be of type SHORT. You may then use a acalcout record (->SynApps) to convert the waveform to float. Best regards, Dirk Szalata, Zenon M. wrote: I have two GPIB instruments attached to ICS 8065 Ethernet - GPIB Controller (according to the manual this device is a replacement for the Agilent E2050 and E5810). I have written two soft IOC's to control and monitor two instruments (one is Agilent 33220A Waveform Generator, the other is Boonton 4500B RF Peak Power Analyzer). Both IOC programs use epics R3-14-9, asyn R4-9, and streamdevice R2-3. The 33220A IOC has a records with SCAN="1 second", which reads the status byte. The 4500B IOC has a waveform record with SCAN="5 second", which is used to read waveform data, a stream of ASCII coded floating point values. The waveform consists of 500 data points. This stream of data is converted to floating point data in a genSub record.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
