Subject: Generating an IOC with SEQ logic in it.
To: <[email protected]>
Date: Thu, 30 Oct 2008 21:51:21 -0500
OK, oh gurus of the EPICS fantastic....
As I understand things, I need to generate an IOC for my system that
contains the sequencer program I wrote to perform some control on one of
our systems.
I have the sequencer program written, and it operates correctly.
When I generated the sequencer program, I installed it inside the
directory that contains all the other components of the system (in my
case, it's </usr/local/EPICS>, and the sequencer source is in
</usr/local/EPICSSRC/modules/soft/seq/seq> ).
I'm having problems understanding how to create the IOC program with
the sequencer component included.
When I try to generate the IOC, I get the message "don't know how to
generate <filename>.o"
I assume I don't have the right configure files included somewhere.
Any suggestions?
Also, I frequently get a message "... too many open files" when I
attempt to make the system.
Any ideas?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Re: Generating an IOC with SEQ logic in it. Andrew Johnson
Prev: RE: CA and data acquisition array with variable length in waveform record) Mark Rivers
Next: Re: Generating an IOC with SEQ logic in it. David Maden
