Subject: Re: recordGenerator record
To: Dirk Zimoch <[email protected]>
Cc: [email protected], Kalantari Babak <[email protected]>
Date: Mon, 27 Oct 2008 10:44:24 -0500
On Monday 27 October 2008 09:48:00 Dirk Zimoch wrote:
> It might be possible to make this thread-safe by disabling interrupts
> before calling dbPvdAdd().
That won't work on any workstation OS, where epicsInterruptLock() just takes a
global mutex so it won't stop another thread from calling dvPvdFind while the
dbPvdAdd() is in the middle of initializing an unused bucket or adding a new
node (unfortunately both actions currently insert their new object before
initializing it completely).
On vxWorks and RTEMS that might be safe as long as the record has been
completely initialized before the lock is released, but I'm not sure you
could safely insert the new record into a lockset since you have to take a
lock to do that, and the OS allows itself to re-enable interrupts if your
code blocks or releases a lock.  Read the vxWorks manual entry for intLock()
for details.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
recordGenerator record Kalantari Babak
Re: recordGenerator record Andrew Johnson
Re: recordGenerator record Dirk Zimoch
Prev: Re: recordGenerator record Dirk Zimoch
Next: RE: EPICS and CAN field bus David Beauregard
Next: areaDetector R1-2 released Mark Rivers
