Three possibilities:
1. use a chain of FLNKs
2. use two fanout records.
3. use a seq record
Why do you need the NOT value?
You could just assign ZNAM to ON rather than OFF in your bi record.
Depending on the serial protocol you might be able to change the stream protocol file.
In an case, I don't think a calc record has B0,B1,... fields, so you would need
a second mbbiDirect record.
eg.:
record(mbbiDirect,"$(PREFIX):DISTATE")
field(DTYP, "stream")
field(INP, "@power.proto mbbiDirect_distate_raw terminal")
field(SCAN, "1 second")
field(PINI, "YES")
field(FLNK, "$(PREFIX):DIOSTATE")
field(NOBT,8)
record(bi,"$(PREFIX):DI0STATE")
field(DESC, "MAIN RELAY")
field(INP, "$(PREFIX):DISTATE.B0")
field(ZSV, "NO_ALARM")
field(OSV, "MINOR")
field(ZNAM, "On")
field(ONAM, "Off")
field(FLNK, "$(PREFIX):DI1STATE")
> I want to get a raw value(8 bit) from hardware, after
> caculating the NOT value of it, 8 bi records will get the
> each bit value. For example, if I get the raw value "0xFE",
> caculate it with NOT operator to "0x01", then bi record 1th
> get the B0 bit, bi record 2th get the B1 bit...etc.
> If I set SCAN field to period of each bi record, maybe I
> can refresh the value. While is it possible only setting SCAN
> field of mbbiDirect record, then arosing all bi records being
> processed?
> I know if I use a fanout record(maybe dfanout record since
> fanout only support 6 values), I can do this. Is there any
> other possible way?
> ps, is there any other way to caculate the NOT value
> without using calc record?
> record(mbbiDirect,"$(PREFIX):DISTATE_RAW")
> field(SCAN, "Passive")
> field(PINI, "YES")
> field(FLNK, "$(PREFIX):DISTATE")
> field(NOBT,8)
> record(calc,"$(PREFIX):DISTATE")
> field(CALC, "~A")
> field(INPA, "$(PREFIX):DISTATE_RAW.VAL NPP")
> field(INP, "$(PREFIX):DISTATE.B0 PP")
> field(ZSV, "MINOR")
> field(OSV, "NO_ALARM")
> field(ZNAM, "OFF")
> field(ONAM, "ON")
> record(bi,"$(PREFIX):DI1STATE")
> field(DESC, "CURRENT TRANSDUCER")
> field(INP, "$(PREFIX):DISTATE.B1 PP")
> field(OSV, "MAJOR")
> field(ONAM,"FAULT")
> field(ZNAM, "OK")
> Thank you very much for your help.
> Best regards
> Geyang 2008-10-15
- Re: RE: a question about mbbiDirect and fanout Silver
- Re: a question about mbbiDirect and fanout Ralph Lange
- a question about mbbiDirect and fanout Silver
Re: EDM xyGraphClass yLabel displaying backwards John Sinclair
Re: LvEPICS on USB Key pre-release Mohan Ramanathan
<2008>
<2008>
