Subject: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit?
To: Tom Cumming <[email protected]>
Cc: [email protected]
Date: Wed, 15 Oct 2008 05:23:58 +0200
Tom Cumming schrieb:
I've hit the 2GB Channel Achiver index file limit. How have people been
dealing with this limit? Is it time to move it up to 4GB? Modern
machines should be able to handle it.
As far as I remember (Kay?) the limit is not imposed by the filesystem used.
The data-structures used within the index and data files hold 32-bit offsets into these files.
And if these offsets go in both directions, we're stuck with the 2GB limit...
If our index-files at BESSY approach the 2GB limit, I usually re-create the index completely from scratch which typically produces a much smaller index-file.
Otherwise, the only way out is to introduce a new file-format and partly re-write the code of the ChannelArchiver-DataStore.
Hope it helps,
Thomas
BESSY GmbH
Albert-Einstein-Str. 15, D-12489 BERLIN
BESSY GmbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult Joachim Treusch
Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
begin:vcard
fn:Thomas Birke
n:Birke;Thomas
org:BESSY GmbH;MBP
adr;quoted-printable:;;Albert-Einstein-Stra=C3=9Fe 15;Berlin;;12489;Germany
email;internet:[email protected]
tel;work:+49 30 6392-4934
tel;fax:+49 30 6392-4859
tel;cell:+49 179 2445891
url:http://www.bessy.de/
version:2.1
end:vcard
Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Prev: epics dbpf problem Shi HaoLi
Next: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? Tom Cumming
Prev: Re: How have folks been dealing with the Channel Archiver's 2GB index file limit? J. Lewis Muir
