David,
any reason why you're not using the alarm handler?
Maren
David Dudley wrote:
I've got a PLC that handles alarm notifications. This PLC runs only 2
things - a 120DB horn, and the brightest strobe light you've ever seen
in your life (OK, some of you guys have probably seen something
brighter, just not me ;-).
When a NEW alarm comes in (which is a output BIT that writes to a PLC
control register), the PLC clears that bit, resets a couple of latching
relays, and then sets off the horn, and/or the strobe. This happens
every time this bit is written as a '1'. As long as the alarm bit in
EPICS is set, I don't want to output the bit to the PLC again. Only
when the bit is initially set to a non-zero do I want to write to the
PLC.
- Re: Process 'bo' on write? David Dudley
- Process 'bo' on write? David Dudley
- Re: Process 'bo' on write? Tim Mooney
October meeting: tarball for IRMIS application layer training Carcassi, Gabriele
Re: Process 'bo' on write? Andrew Johnson
<2008>
<2008>
