Subject: Re: epicsThreadSleep() and epicsThreadSleepQuantum()
Cc: [email protected]
Date: Wed, 01 Oct 2008 16:45:03 -0400
On 9/29/08 7:05 PM, Andrew Johnson wrote:
snip
> If anyone has any better ideas I'm open to them (working code particularly
> welcomed), but this issue is not going to be solved in R3.14.10.
Hi, Andrew.
As a first step, I could see adding a function such as
  void epicsThreadSetSleepQuantum(double quantum);
If someone knows what the sleep quantum should be for their particular
machine (by experiment or otherwise), they can set it explicitly (at IOC
boot time or whenever).  If this function is never called,
epicsThreadSleepQuantum() behaves just as it does now.  But if
epicsThreadSetSleepQuantum() has been called, epicsThreadSleepQuantum()
returns the explicitly set quantum.
A step beyond this first step might not be a good idea.  But if one was
to try to implement a step 2 by tackling the problem of automatically
determining the actual sleep quantum, perhaps a function could be added
with this signature:
  void epicsThreadCalibrateSleepQuantum(void);
This function would use an algorithm to determine the actual sleep
quantum and set it via step 1's epicsThreadSetSleepQuantum().  If the
user would like to potentially get a more accurate sleep quantum than
what is reported by epicsThreadSleepQuantum(), he or she could call this
function (at IOC boot time or whenever).  Again, the default is the
behavior we have now; the user would have to explicitly call this
function to get this new behavior.
What algorithm to use is where things might become difficult.  I could
see it being difficult to come up with an algorithm that would correctly
determine a good actual sleep quantum for the wide range of hardware and
operating systems on which EPICS runs.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT/CARS
epicsThreadSleep() and epicsThreadSleepQuantum() Mark Rivers
Re: epicsThreadSleep() and epicsThreadSleepQuantum() Andrew Johnson
Prev: Re: epicsThreadSleep() and epicsThreadSleepQuantum() David Dudley
Next: Re: Base R3.14.10-RC1 Released J. Lewis Muir
Prev: Re: epicsThreadSleep() and epicsThreadSleepQuantum() Andrew Johnson
Next: Base R3.14.10-RC1 Released Andrew Johnson
