Subject: |
Re: How to be warned when a record processing is ignored because already busy (PACT=1) |
Ben Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 30 Sep 2008 21:33:55 +0200 |
On Dienstag, 30. September 2008, haquin wrote:
> My problem is the following:
> Sometime though the last value is in the VAL field of the Waveform
> record it is not written via Modbus.
> I have already investigated on the Asyn/Modbus side, but it turns out
> that when the problem occurs Asyn/Modbus is not even called.
> It seems that the problem occurs when the Calcout record requests the
> Waveform record for a new Modbus write access but the Waveform record is
> still busy with the previous one...
> Can someone explain me how to be warned or informed when the processing
> request of a record is ignored because it is still busy (PACT=1).
I have no good answer for your question about diagnosing PACT state, but
there is one thing you could do that might help solve your lost-writes
problem: You can use "Async Soft Channel" support for the record that
writes through the link. This will make the writing record asynchronous if
the target record is, i.e. it will remain active (PACT=1) as long as the
target record is active. OTOH, depending on your application this might
merely push the problem upwards...
Cheers
Ben
- How to be warned when a record processing is ignored because already busy (PACT=1) haquin
Re: An error when building EPICS base R3.14.9 on Solaris 8 Andrew Johnson
Re: Question about a tutorial wiritten by Norum Ben Franksen
<2008>
Re: How to be warned when a record processing is ignored because already busy (PACT=1) Tim Mooney
Question about a tutorial wiritten by Norum Silver
<2008>
