Subject: Re:Re: Question about a tutorial wiritten by Norum
To: "Eric Norum" <[email protected]>
Date: Wed, 1 Oct 2008 00:14:27 +0800 (CST)
 hi, Eric:
I follow your tutorial, but seems there is sth. wrong in my test code.
this is dbtr message:
epics> dbtr AB300:FilterWheel:fbk
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 0
ASG:                BKPT: 0x00          DESC: Filter Wheel Position
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DTYP: AB300         EGU:                EVNT: 0             FLNK:CONSTANT 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV: NO_ALARM       HYST: 0             INP:GPIB_IO #L0 A0 @2
LALM: 0             LCNT: 0             LLSV: NO_ALARM      LOLO: 0
LOPR: 0             LOW: 0              LSV: NO_ALARM       MDEL: 0
MLST: 0             NAME: AB300:FilterWheel:fbk             NSEV: NO_ALARM
NSTA: NO_ALARM      PACT: 1             PHAS: 0             PINI: NO
PRIO: LOW           PROC: 0             PUTF: 0             RPRO: 0
SCAN: Passive       SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT
SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT       STAT: UDF
SVAL: 0             TPRO: 0             TSE: 0              TSEL:CONSTANT
UDF: 1              VAL: 0
epics> 2008/10/01 00:11:33.540 192.168.1.103:4001 write 2
Â\201
epics> 2008/10/01 00:11:35.468 192.168.1.103:4001 read 4
U\020\000\020
2008/10/01 00:11:37.465 AB300:FilterWheel:fbk convert failed Invalid reply
I change the code in devAB300.c like this:
  {&DSET_LI, GPIBREAD, IB_Q_LOW, "\252\201\000\201", NULL, 0, 10,
   convertCurrentReply, 0, 0, NULL, NULL, NULL},
why can I only send 2 bytes to device through an Ethernet/serial box?
How to change the Oct format to Hex/Dec in st.cmd?
Thanks a lot again.
å2008-09-30ï"Eric Norum" <[email protected]> åéï
>On Sep 30, 2008, at 7:58 AM, Silver wrote:
>> hi, all:
>>  I want to write a driver for one of our serial devices, so I read
>> "How to create EPICS device support for a simple serial or GPIB
>> device". (http://www.aps.anl.gov/epics/modules/soft/asyn/R4-9/HowToDoSerial/tutorial.html
>> While I have several questions:
>>  1. in the tutorial, it said:
>> Command array index 0 â Device Reset
>> {&DSET_LO, GPIBWRITE, IB_Q_LOW, NULL, "\377\377\033", 10, 10,
>>       NULL, 0, 0, NULL, NULL, "\033"},
>> I don't understand what's the meaning of "\377\377\033", does it
>> mean "377" is oct number?
>Yes.  That's standard C syntax.
>If you prefer hexadecimal the equivalent would be "\xFF\xFF\x1B".
>>  2. in function "convertPositionReply" and "convertStatusReply",
>> first time, pli->val = pdpvt->msg[0];
>> second time, pli->val = pdpvt->msg[1];
>> Does it mean the AB300's response data begin from different
>> position? can anyone give me some explanation?
>The AB300 response always contains both position information (in the
>first character) and status information (in the second character).
>> I have never used GPIB device before, so forgive my innocence.
>> Thanks a lot in advance.
>If your device is IEEE-488.2 compliant the makeSupport .pl command in
>the ASYN distribution will set up a number of command table entries
>that you could study.  The command usage is:
>/bin//makeSupport.pl -t
>devGpib
>Eric Norum
[åå] çæååèå26éæå
Re: Question about a tutorial wiritten by Norum Eric Norum
Question about a tutorial wiritten by Norum Silver
Prev: Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1 Andrew Johnson
Next: Re: Question about a tutorial wiritten by Norum Eric Norum
Prev: Re: Question about a tutorial wiritten by Norum Eric Norum
