Haquin, You can read the PACT field immediately before processing
the calc record, and have the waveform record forward link to a
record that clears the value you just read. This may produce
some short-lived false positives, because it's possible for the
waveform record to complete between the read of its PACT field and
the processing of the calc record.
haquin wrote:
Hi all,
Here is what I do:
a Calcout record output its value into the VAL field of a Waveform
record (using a Process Passive link triggering the processing of the
Waveform).
Then the Waveform record performs a Modbus/TCP write access with
Asyn/Modbus device support.
My problem is the following:
Sometime though the last value is in the VAL field of the Waveform
record it is not written via Modbus.
I have already investigated on the Asyn/Modbus side, but it turns out
that when the problem occurs Asyn/Modbus is not even called.
It seems that the problem occurs when the Calcout record requests the
Waveform record for a new Modbus write access but the Waveform record is
still busy with the previous one...
Can someone explain me how to be warned or informed when the processing
request of a record is ignored because it is still busy (PACT=1).
I tried setting field TPROC=1 to check if the Waveform trace is missing
when the problem occur,
but this is intrusive and the problem is then not reproducible...
thanks.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- How to be warned when a record processing is ignored because already busy (PACT=1) haquin
Re: Question about a tutorial wiritten by Norum Eric Norum
Re: vxWorks 6.6 compile problem for EPICS R3.14.10-RC1 Andrew Johnson
<2008>
Re: How to be warned when a record processing is ignored because already busy (PACT=1) Ben Franksen
<2008>
