Subject: Re: ASYN R4.10 Release - code depreciation
To: [email protected]
Date: Fri, 26 Sep 2008 12:24:52 -0500
On Friday 26 September 2008 04:22:32 Dirk Zimoch wrote:
> The gnu compiler has an extension called attributes. One can mark a
> function, variable, or type with __attribute__((deprecated)). (For other
> compilers, define an empty macro __attribute__(x) for compatibility.) This
> produces a compiler warning when the function or variable is used.
For R3.14.10 I've just added EPICS_DEPRECATED to compilerDependencies.h which
is where we normally put this kind of macro.  On GNU compilers it expands to
__attribute__((deprecated)), on other compilers it is empty.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: ASYN R4.10 Release - code depreciation Pearson, MR (Matthew)
Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Prev: Re: EDM font sizes Kevin Anderson
Next: Re: SIemens PLCs Emmanuel Mayssat
Prev: Re: ASYN R4.10 Release - code depreciation Dirk Zimoch
Next: Modbus Mark Rivers
