Subject: DBFLAGS in RULES.Db
To: <[email protected]>
Date: Fri, 5 Sep 2008 08:45:37 -0700
Hello,
In the following tech-talk message on April 16, 2008:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00355.php
I suggested a change to epics/base/configure/RULES.Db that allows building databases using msi where the substitutions file uses already installed databases for the application (plus any databases from the modules listed in RELEASE).  This is for when you build databases on top of databases for an app by separating the Db into multiple directories that are built in the right order.  Going back to the thread for the above message has more detail.
The change for the RELEASE modules was made but not the change for the app's own installed databases.  Could someone with access to the CVS repository please change RULES.Db as follows:
# dbExpand
INSTALL_DBDFLAGS += -I $(INSTALL_LOCATION)/dbd
DBDFLAGS = $(USR_DBDFLAGS) -I . -I .. $(INSTALL_DBDFLAGS) $(RELEASE_DBDFLAGS)
DBFLAGS = $($*_DBFLAGS) $(USR_DBFLAGS) -I. -I.. $(RELEASE_DBFLAGS)
To:
# dbExpand
INSTALL_DBFLAGS += -I $(INSTALL_LOCATION)/db
DBFLAGS = $($*_DBFLAGS) $(USR_DBFLAGS) -I. -I.. $(INSTALL_DBFLAGS) $(RELEASE_DBFLAGS)
Thank you,
Stephanie Allison
Re: DBFLAGS in RULES.Db Andrew Johnson
Prev: Re: sseq link problem on Linux Tim Mooney
Next: Re: DBFLAGS in RULES.Db Andrew Johnson
Prev: RE: Gateway problem .... more info Jeff Hill
