Emma,
could that be a scanOnce problem rather than a sseq problem?
HTH,
Maren
Shepherd, EL (Emma) wrote:
Hi Andrew,
Thanks for the reply; yes sseq is part of the synApps package (we use it
so regularly I sometimes forget it isn't in base!).
Actually the link is listed as being connected, and in fact it does
update properly when the record is processed or when the value of the
linked record changes. The difference in behaviour between vxWorks and
Linux is just concerning initialisation - on vxWorks the link gets
processed when the IOC first boots up but on Linux it doesn't.
Emma
-----Original Message-----
Sent: 04 September 2008 21:04
To: [email protected]
Cc: Shepherd, EL (Emma)
Subject: Re: sseq link problem on Linux
Hi Emma,
On Thursday 04 September 2008 13:46:58 Shepherd, EL (Emma) wrote:
I recently encountered an interesting problem when moving
an IOC from
vxWorks to Linux (RedHat). The database contains a number of sseq
records with CP input links to pull across some data from
another IOC.
This happens whenever one of the links changes, but also
when the IOC
boots up for the first time. This worked fine on vxWorks, but on
Linux the links do not get updated when the IOC boots up. It's not
just an occasional failure, it just never worked. I
changed the sseq
records to transforms and it now works fine. In both cases I had
PINI=YES.
Hmm, I would guess the the sseq record type is from synApps.
However assuming
that it's just using a standard dbCa link, what does "dbcar
'', 1" show from
one of the Linux IOCs where the link is not being updated?
Does it list that
record link as disconnected?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- RE: sseq link problem on Linux Shepherd, EL (Emma)
Gateway problem .... more info Angelic Ebbers
<2008>
Re: sseq link problem on Linux Tim Mooney
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
