Title: No route to host
Hello,
à Unable to connect because "No route to host"
It would appear that there is, as suggested by the message, an
IP level issue with Ârouting frames from pc1 to pc2. Is it possible to use the
ping command (i.e. âping pc2â) to contact pc2? If that does not work then type ânetstat
ârâ on pc1 and compare that output to the same type of ânetstat ârâ command on
PC3.
à A call to "assert (_pTargetMutex == &
mutexToVerify)" failed in ../../../include/epicsGuard.h line 84.
I am not sure what has caused this message â which is somewhat worrisome.
It would be interesting to run the code under gdb, and obtain a stack trace for
the thread that printing this message using the bt command (issued in gdb) .
The stack trace produced in gdb will be easier to decipher if the CA client
library has been built properly for debugging.
Jeff
Hello,
When I'm using "caget" in a PC No.1 to read data in PC No.2,
the following message displayed:
CAC: Unable to connect because "No route to host"
CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "10.10.254.124:5064"
Source File: ../cac.cpp line 1126
Current Time: Mon Sep 01 2008 11:04:15.122863235
Channel connect timed out: 'SR-BI:ConfCal' not found.
A call to "assert (_pTargetMutex == & mutexToVerify)" failed in
EPICS Release EPICS R3.14.9 $R3-14-9$ $2007/02/05 16:31:45$.
Current time Mon Sep 01 2008 11:04:16.091265952.
Please E-mail this message to Jeff Hill [email protected] or to
[email protected]
Calling epicsThreadSuspendSelf()
If using "caget" in a PC No.3 to read data in PC No.2, the
Source File: ../cac.cpp line 1142
Current Time: Mon Sep 01 2008 12:29:01.861896000
Here is the basic information:
PC No.1
linux kernel: 2.6.23.1-42.fc8
epics_base version: 3.14.9
PC No.2
linux kernel: 2.6.9-42.0.3.EL
epics_base version: 3.14.8.2
PC No.3
linux kernel: 2.6.11-1.1369_FC4
I have used "export EPICS_CA_ADDR_LIST" command in both PC No.1 &
3 , and the IOC runs normally in PC No.2.
How can I solve this problem?
Thank you.
- No route to host 黄思婷
Re: ASYN connection concerns Benjamin Franksen
RE: RTMES vs VxWorks Dalesio, Leo
<2008>
Re: No route to host Ralph Lange
Infrared thermometer Pedersen, UK (Ulrik)
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
