Subject: CAN232
To: "EPICS Techtalk" <[email protected]>
Date: Wed, 27 Aug 2008 12:10:31 -0700
I bought a CAN232 (EasySync) rs232 to can converter.  My goal is to implement an epics soft IOC to communicate with a Wiener VME crate which has the CAN interface.  So far, I am able to "talk" with the converter itself (the "V" command returns the version numbers).
I have built a simple "straight through" can cable (using pin 2, 3, and 7), terminated as recommended in the instruction manual and connected the can232 to the VME crate.  When I issue a simple can command I get no response from the crate.
Has anyone used this device in a similar setup?  Any ideas will be greatly appreciated.
Thanks in advance,
Zen
Prev: accessing a slice of an array field Dehong Zhang
Next: Re: PV Gateway Andrew Johnson
Prev: RE: accessing a slice of an array field Jeff Hill
Next: RE: CAN232 David Beauregard
