Subject: RE: ASYN driver
To: <[email protected]>
Date: Tue, 26 Aug 2008 12:37:28 -0500
Found it.
One of the others here in the office was having problems connecting
with a remote unit, and put code into what he thought was a 'private'
copy of the asynManager.c file to print some information out for him.
All corrected.
David
>>> "Mark Rivers" <[email protected]> 8/26/2008 12:01 PM >>>
David,
What asyn driver are you running?  drvAsynSerialPort, drvAsynIPPort,
or
some other driver?  Neither the serial or IP port drivers contain that
error message (at least the most recent release, R4-9, does not).
In general you turn off all asyn messages on a port by setting the
asynTraceFlag to 0
asynSetTraceMask "port" addr 0
addr is typically 0, but it could have other values for multi-device
drivers.
-----Original Message-----
[mailto:[email protected]] On Behalf Of David Dudley
Sent: Tuesday, August 26, 2008 11:42 AM
To: [email protected]
Subject: ASYN driver
I'm getting messages on the IOC console whenever I'm running the ASYN
driver similar to
"writeRaw: Need to write 8 chars"
"writeRaw: Write to 4  wrote 8 chars"
How do I turn them off?  I've got the debug fields set to zero.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
ASYN driver David Dudley
RE: ASYN driver Mark Rivers
Prev: RE: ASYN driver Mark Rivers
Next: Lead Software Engineer or Lead Software Scientist at MRO Chethan Parameswariah
