Andrew Johnson wrote:
On Thursday 21 August 2008 09:40:27 I wrote:
The latest version of the gateway in CVS has the following added to the
gateway/Makefile which completely avoids the need to install those files:
# need access to casCtx.h
USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
I think I lied; those lines are already in David's version of the gateway code
(2-0-3-0) but they won't work if his EPICS_BASE is pointing to a tree that
was installed in a different location to the source code by setting
INSTALL_LOCATION in the base/configure/CONFIG_SITE file.
Manually installing the private header files like David did was probably the
easiest way for him to fix the problem at the moment, although he could also
have modified the gateway's Makefile to point that -I option to the original
source for Base. We need to get the additional APIs included in CAS to fix
this properly.
If you automatically install include files and then change the line
above to something along the lines of
USR_INCLUDES += -I$(EPICS_BASE)/include
that should work.
Aloha,
Maren
- PV Gateway David Dudley
- Re: PV Gateway Dirk Zimoch
- Re: PV Gateway Andrew Johnson
Re: Motor home status Maren Purves
PV Gateway and IOC running Epics 3.12 Angelic Ebbers
<2008>
Re: PV Gateway Gasper Jansa
<2008>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
