Subject: Re: PV Gateway
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Thu, 21 Aug 2008 17:54:54 +0200
Hi
It is used to obtain the mask with which the client requested a monitor.
Best Regards
Gasper
Andrew Johnson wrote:
On Thursday 21 August 2008 02:32:45 Dirk Zimoch wrote:
I think, the two headers were supposed to be "private" to cas. But since
the gateway needs them the base Makefile should be modified to install
them. That's what I did and it works fine. However I didn't try 3.14.9. but
run with 3.13.8.2.
The latest version of the gateway in CVS has the following added to the gateway/Makefile which completely avoids the need to install those files:
# need access to casCtx.h
USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
This method also makes it a little more obvious that the gateway code is using private APIs inside CAS that could change as the CAS implementation changes.
I have added a bug report to Mantis
(http://www.aps.anl.gov/epics/mantis/main_page.php).
Someone could add that information to the gateway documentation. :-)
For maintainability reasons I much prefer that we modify CAS to make the necessary API routines or their equivalents available through the official headers. Installing or using private headers makes the innards of the CAS implementation visible to applications, which means that future changes to the implementation of CAS can break the external code that has started using these private APIs. I'm sure Jeff will agree with me on this point.
Unfortunately this issue has surfaced too late for any changes to CAS to be included in R3.14.10, but I hope that we'll be able to work something out soon afterwards and provide a patch file for CAS to be used when building the gateway until the next Base release.
Dirk, these headers were added by your patch to the gateway that Janet applied last year, can you explain to Jeff what functionality you need from CAS.
- Andrew
PV Gateway David Dudley
Re: PV Gateway David Dudley
Re: PV Gateway Dirk Zimoch
Re: PV Gateway Andrew Johnson
Prev: Re: PV Gateway Andrew Johnson
Next: EPICS meeting in Padua - please forward agenda to beam line people in your lab. Might be interesting to them. Dalesio, Leo
Prev: Re: PV Gateway Maren Purves
Next: Re: PV Gateway Dirk Zimoch
