On Thursday 21 August 2008 09:40:27 I wrote:
> The latest version of the gateway in CVS has the following added to the
> gateway/Makefile which completely avoids the need to install those files:
> # need access to casCtx.h
> USR_INCLUDES += -I$(EPICS_BASE)/src/cas/generic
I think I lied; those lines are already in David's version of the gateway code
(2-0-3-0) but they won't work if his EPICS_BASE is pointing to a tree that
was installed in a different location to the source code by setting
INSTALL_LOCATION in the base/configure/CONFIG_SITE file.
Manually installing the private header files like David did was probably the
easiest way for him to fix the problem at the moment, although he could also
have modified the gateway's Makefile to point that -I option to the original
source for Base. We need to get the additional APIs included in CAS to fix
this properly.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: PV Gateway Maren Purves
- PV Gateway David Dudley
- Re: PV Gateway Dirk Zimoch
- Re: PV Gateway Andrew Johnson
Re: PV Gateway David Dudley
Re: PV Gateway Gasper Jansa
<2008>
<2008>
