Subject: Re: PV Gateway
To: <[email protected]>
Date: Wed, 20 Aug 2008 18:02:24 -0500
At least to build the gateway, you need casCtx.h and casHdrLargeArray.h
(think I got that one right?).
Looking at src/cas/build/Makefile, did they perhaps get left out?
I added them into the file and rebuilt base, and they got copied into
the destination.  Should all the include files be listed, or is there
some subset, or was that a mistake?
Gateway now builds correctly, and looks like it's going.
David
>>> "David Dudley" <[email protected]> 8/20/2008 5:49 PM >>>
Well, getting closer, but still a mystery.
For some reason, when I build the system from a blank start (did make
clean before running make),  the build dances all around the 'generic'
directory in the src/cas directory, but never enters it, or copies
anything from it into the destination.
Have I made a configure error?????
David
>>> "David Dudley" <[email protected]> 8/20/2008 5:30 PM >>>
I actually found a file, in my base source directory, by that name,
but
it didn't get copied into the installation include files.  Can I just
copy it over there, or is there something else I also need to do?
David
>>> "David Dudley" <[email protected]> 8/20/2008 5:27 PM >>>
I'm trying to compile Gateway 2_0_3_0, but I keep getting a failure
for
casCtx.h when I try to compile.
I've got the 3.14.9 version installed (at least I think so), but the
only file I have in the includes is: casdef.h.
Did I miss something?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:826-1265
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
TITLE:Functional Analyst
END:VCARD
Re: PV Gateway Dirk Zimoch
PV Gateway David Dudley
Re: PV Gateway David Dudley
Prev: Re: PV Gateway David Dudley
Next: db question about S7-PLC driver marco_hair
Next: Re: PV Gateway Dirk Zimoch
