Hi Chen,
> I know I can use
> dbLoadRecords ("db/test.db","device=${DEV},channel=1")
> dbLoadRecords ("db/test.db","device=${DEV},channel=2")
> dbLoadRecords ("db/test.db","device=${DEV},channel=3")
> dbLoadRecords ("db/test.db","device=${DEV},channel=4")
> in st.cmd script and epics will get the system environment "DEV" so
> that I don't need to modify my ioc package and just use
> export DEV=blahblah
> on each device. But I kind of like my st.cmd script to be clean and neat,
> thus I made some .substitutions file like:
> file "db/test.db" {
> pattern { device, channel }
> { "${DEV}", 1 }
> { "${DEV}", 2 }
> { "${DEV}", 3 }
> { "${DEV}", 4 }
Let's say the "some .substitutions file" had a name like "testAll.substitutions" and that you add a line to your Makefile like this:
DB += testAll.db
The build should create testAll.db from your testAll.substitutions file (I use "should" since I don't know what version of epics you are using).
> For your information, I may have many lines, so the latter is actually
> I preferred. But when I put
> dbLoadTemplate "db/test.substitutions"
If you have the build create "testAll.substitutions", then you would add this line to your st.cmd:
dbLoadRecords ("db/testAll.db","device=${DEV})
Stephanie Allison
- How to pass system environment to .substitutions? Zhichu Chen
Agenda for Padua Dalesio, Leo
<2008>
Fwd: How to pass system environment to .substitutions? Zhichu Chen
<2008>
